TSXPremium PID output
bayeibrahima
Sep 2010
DAKAR
188
Hello to all
I have trouble on an output with TSX Premium 57253. I use PL7 Pro.
When connected online looking at the ladder; the contact associated to a bit memory M1066 (PID output) is deactivated; hence the relay output is off and the plate doesn't heat.
I've transfered the same copy of the programm to the plc; but the default remains.
Do someone knows more about PID regulation on this type of processor
Is there a way to activate this bit?
Hope to read you soon.
Best regards.
91
Hello, I have a motor that we are sending a RPM Speed Output from 0-100% to the VFD. However, the Motor HP needs to be limited to 6000 HP and the...
100
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
627
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
975
How can I connect PID Output to a valve. In ladder logic program is there any logic do I want to add between valve and PID? PV=SP What will be the...
430
