Turning Device and Embossing Device
ferdiecobilla
Dec 2003
manila,philippines
Turning Device
A turning device transfers parts from one conveyor belt to another (which is running in the opposite direction).
When push button (s1) is pressed, the frame of the turning device is advanced by cylinder A. The part is then transferred and moves on in the opposite direction.
When the push button (s2) is pressed, the frame is moved back into the initial position (cylinder A retracts).
EMBOSSING DEVICE
A stamping device can be operated from three sides. Each workpiece is fed in by a guide and in the process contracts two of the three signal generators (proximity sensors) B0, B1, B2. This causes a pneumatic cylinder to be advanced via a solenoid valve (y1) and a recess is punched into the workpiece. The embossing process is to be triggered when two signal generators respond. For safety reasons the cylinder must not extend when all three signal generators are contacted.
These are some of the exercises we have in our plc subject. I would like to ask some help in solving them by providing me the respective ladder diagrams. I will be most grateful and am looking forward for the answers. Thank you.
Providing you "the respective ladder diagrams" is not considered "some help in solving them"... (n)
By the way, I think the first one could be quite easy if you'd bother to think about it... :rolleyes:
beerchug
-Eric
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
We have a Pinnacle power supply from Advanced Energy which we'd like to control using TwinCAT 3, via an EL6002 and RS-232. I got the...
747
I have 3 koyo PLC's in series. The 1st and 3rd are reporting values correctly but the 2nd is reporting negative values. The values in the PLC and...
1,423
I'm very new to the PLC world, and was wondering if I could take an .apb file and turn it into a .mer file. Is this possible? And if so, how would...
1,274
I need to sort pumps based on runtime from shortest to longest then turn them on in order that they are sorted. I know I can create an array for...
3,838
