Twido suite programming
Jbeard
May 2019
Tn.
I'm working with twidosuite program for a few twido plc's I have in my school system. My question is how do I program the PLC to control a vfd. I can program the PLC to turn the vfd on/off but I can't figure out out to make the 0 to 10 volts for the reference signal to make the vfd ramp up and down using a set temperature. Can someone give me some pointers on how to do that. Thanks.
Do you have analogue input and output modules on the PLC?
Normally you'd use a PID loop to compare the temperature feedback(analogue input) with the set point and adjust the VFD speed using the analogue output.
Yes I do have the input and output modules. I can write using temperature to turn on pumps and other equipment but I can't figure out how to control a vfd. I kind of figured it was with a PID but none of the documentation is of much help to me, I don't understand them. Would you know how to write the PID function?
I'm trying to learn how to reprogram some of these twido plc's I have. Can someone give me an example of turning on and off a output with a...
1,140
Hi, I created a program and compiled it with no errors, changed the program hardware configuration to match the plc. If I try to connect I...
1,918
Hello, I am trying to install the Twido Suite Version 2.33.00 on my windows 10 laptop, and I am getting this error: Regsvr32 error on...
2,580
Hello EveryOne...!!! Please Let me Know if this could be possible..!!! I want to connect twido suite 2.2 and Citect scada over local address of...
1,787
Can you guys please help? I have a machine using the Twido PLC. I would like to upload the program from the controller to my PC. I assume the PLC...
3,379
