TwinCAT 3.1: restore existing variables links
karthik.ch
Mar 2019
Augsburg
Hello ALL,
Firstly, I am a complete beginner in PLC's, so excuse me if the question doesnt make proper sense. I have a solution file which was working fine with the CX 9020 PLC. Now, I changed the PLC (CX 5130) but still running the same old solution. Now, the problem is, the variables links are disappeared and I think I need to link them again newly. My question, Is there a way to restore all the previously linked variable addresses? NOTE: the terminals and the connections remains same for both PLC's. Hopefully, waiting for cool positive reply. Thanks in advance.:sick:
I believe the way to do this is to back up your mappings (prior to changing the controller) then restoring them. As long as your variable names and I/O configuration are identical, it should work.
It sounds like you already changed your controller though so I don't know if there's another way once they're wiped out...
BiaDZ7qdUEbSB97cxKAMXKEMfF4in6zEXnmC3nl3g2BjeGjdbipvq+MIBOvbhLXCBMrRygeO3seOZthsX8BZ4B9LHBeGgA7hAGVq5QLCxwAUWiQi+9t0oQ1sXmN+s8ooNXuACZegzduhvQfJ26MYFAR5aoQvEe+AddAAFLlCGVr8pRvFHy4LqAuaBooRnK+ICtm9sf4OOpuM1gPl24AIQKDpca6RhxCcsgewHEQcuUAZcwEyALmB2ChA3gQuUARcgWgUuUAZcgGgVuEAZcAGiVeACZcAFiFaBC5QBFyBaBS5QBlyAaBW4QBlwAaJV4AJlrH+3EkG0Cu+zChcAAAiBCwAAFLgAAEAIXAAAoMAFAABC4AIAAAUuAAAQAhcAAChwAQCAELgAAED5f8SCS7CCPBwMAAAAAElFTkSuQmCCAA==
Hi Kolyur,
I have all the mappings in the solution file as it is. When I load the solution, the EtherCAT master device for the old PLC (CX9020) also shows up, and the variables are perfectly linked. When I search for new devices, new EtherCAT master for (CX5130) also appears, but without links. Now, i want to have all the previous links in this new device. Hope it is clear to you. Thank you for the reply.
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
86
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
73
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
156
