TwinCAT 3, NC / Motion, NC control, how to?
tevious
Feb 2015
Balingen
22
Hello,
I completed a first simulation project with TC3 to control a single axis in PTP mode, using both NC / Motion and PLC (thanks to TC2_MC2) working together.
First, I'd to know what is the difference between NC I module and CNC module?
Now I'll have to make a more complicated project with interpolation. This time I would like to place the head with a tool of a 3D robot to a position.
In the NC / Motion part I declare my axis as usual and now I need to add a new channel for interpolation.
Then, I declare my PLC as usual too...
But now what can I do?
Usually, NC unit can be driven using g-code, but I don't want to use that. I know that TC allow NC driving with FB, but I don't know which ones and how to use them.
For PTP it was easy with the FB of TC2_MC2 and some basic inputs to choose a position to reach and to run the process.
But now, I read some g-code examples and Beckhoff's help and it's more complicated than just giving a target position.
Do you have some tuto, examples or resources to manage this, I don't know how to start :rolleyes:
Thanks.
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
88
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
106
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
73
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
156
