Twincat ADS troubles
Bakkei
May 2006
Arnhem
63
I have two applications (VB.NET and LABview) running on a CX2100, both communicating over ADS with the Twincat program also running on this system.
Everything is running fine, except every now and then (Lets say once or twice a day) the communication gets interrupted. After this moment most variables on the VB.NET application are still up-to-date on the VB.NET application, but some are frozen from that moment on.
Anybody any idea where I could look for a solution?
I had a similar problem with com port communications. I ended up writing an ascii file on the computer each time I communicated through the port. Another program was then written to read this ascii file. If the time was greater then the time between the communications, I would kill and restart the applications again.
Regards,
Are you using DeviceNotification or polling the variables?
Both. Some variables are polled every 500mSec. Others are read when an event is raised by DeviceNotification.
However it seems that the problem may not have been directly related to ADS communication. In the Visual Basic application there was a failure when a value that was cast to an INT16 had the most significant bit set. When the value was casted to an Integer this problem did not occur. At the same time there was a completely unrelated issue with the LABview application. The latter is not resolved yet as I'm not the author of this program.
If the problem after all still seem related to ADS I will get back in touch.
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just...
2,199
Hello: I have a TwinCAT embedded PLC and for years I was able to access it through the AMS NetID. Recently updated Windows 10 and I was not able...
16,311
Hey i want to read structures with an ads connecton with a c# programm. But i dont know how this works. can anyone help me Thanks
2,167
Hello, I'm currently trying to connect my vb.net application with my Twincat PLC. This is what I have so far (i call it from a sub): Dim ads As...
4,418
Hi I worked three days ago twincat3 was working well. Today I am getting an error : Error 15 02/11/2017 23:33:54 223 ms | 'TwinCAT System'...
5,584
