ADS exchange Data between Twincat and VBS script
jenako
May 2019
Northampton
Hello. I am trying to do some basic file operations (move file from one folder to another, rename file in the new folder etc) and usually I just call a vbs script using NT_STARTPROCESS function block in Twincat. However this time I need the name of the file to be created, to be determined by my PLC program, so there needs to be a form of communication between my VBS script and the PLC program. I have been looking at the documentation shown in
https://infosys.beckhoff.com/englis...tcscriptdll/html/TcScriptDll_Sample01.htm&id=
and it is suggested that the following vbs code should allow to connect to Twincat and write to the PLC variable (I am trying to establish the vbs-Twincat connection first). However, when I run the vbs given in my attachment I receive the error "Active X component cant create object".
Seems like there is some step missing. Any advice/tip will be highly appreciated thank you in advance for your kind consideration.
NT_StartProcess vbscript
Hello,
I want to launch a vbscript from TwinCAT NT_StartProcess, I don't know how to do it?
Could you tell me how it would be?
Thank you so much for everything
Hello folks! Never been here before but I have a question that's been bugging me for a while. I recently got a job at a chemical plant that's...
338
Hi, I have to modify a client's aveva edge application and I'm not sure how to download the modifications without breaking anything :) Setup...
301
I just asked tech support at Phoenix Contact a question and the answer is making me think maybe I have misunderstood relay ratings for years...
2,867
Not sure if it's a setting somewhere I can change or if it's normal/expected behavior, but if I'm away from this forum for over a day or so (like...
600
So my panelview plus 600 is giving me these performance characteristics and I'd like to know if I should be worried at all (see attached):
1,991
