Twincat NT_**** (FBs)
Hello PlayerByNature. You should check each individual function block that you want to use. For example, NT_Shutdown is documented here...
http://infosys.beckhoff.com/content...cplclibutilities_nt_startprocess.htm?id=11381
At the bottom of the page, it indicates that as of 2.10 build 1301, both the x86 (CX1xxx, CE or XPe) and ARM (CX9xxx, CE Only) target systems are supported.
T_AmsNetID is the AMS Net ID of the Beckhoff Station to execute the function on. For example, one PLC can execute the code for an NT_Shutdown on a remote PLC over the network.
If you simply leave the NetID feild blank, it will assume the local machine and shut down the local machine.
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
115
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
273
Hi! I am trying to run the 'SimpleSample' (https://infosys.beckhoff.com/content/1033/TF5100_TC3_NC_I/Resources/3438746891/.zip ) to understand the...
120
I am developing a library in twincat and one of the function uses IID_ITcVnAccess_TcVnPoint2_DINT and the definition of this type is defined in...
93
Sorry if this has been asked before, and apologies if this seems like a trivial issue, but I am new to Beckhoff and have been banging my head...
173
