I need to have two pieces of equipment to run in sync. although one motor runs with a 5:1 gearbox and another has a 15:1 gearbox.How can I make these two machines run in sync??
I'm needing to use an encoder to track revs, With ppm, how do I wire the encoder to the PLC AB 1200 w/2 in/2 out analog I/O add on module.
I only need z pulses, then I believe I need to write program and make a numeric value(ratio) to send the 0-12 v signal to the vfd on other motor. I understand ladder logic but this something I haven't had to do yet.
This appears to be easier::::
Or can I use the 0-12v signal from the first vfd and reduce/increase that value incrementally through the PLC(program) to make a signal that would go out to the other VFD. these two machines need to start(ramp up and down in sync)
Compensatimg VFD the 0-12v signal does not make this happen, the two pieces of equipment are too far different in the gear ratios
RandyO
RandyO
