Two Variable Problem
bernie_carlton
Apr 2002
Yakima, Washington
6,413
I need some help with a timing scenario. I have a belted
conveyor which carries a product toward a flighted machine.
At the end of the belted conveyor is a device which can lift
the product above the belts, stopping it until a proper time
to release it in time with the flighted machine. I receive
one pulse per flight from the machine. Up until now the
speed of my belted conveyor was constant and that of the
flighted machine was variable.
I took the time between the pulses from the flighted machine
and used it as 'x' in the old 'y = mx + b' formula. It wasn't
hard deriving the 'm' and the 'b' by two settings at a high
speed and low speed of the flighted machine. For this
'one-variable' problem it was easy applying the slope and
y-intercept method we all learned in algebra. This gave me
a delay time after the pulse at which to release the product.
Worked great. Now here's the problem.
They want to make the belted conveyor's speed variable also.
I know I'll have a formula like 'z = ax + by + c' with 'z' as
my resultant timing, 'a' as the multiplier times the timing
from the flighted machine, 'b' as the multiplier times a similar
timing I'll get from my, now variable, belted conveyor, and 'c'
as an offset. What do I do to derive the 'a', 'b' and
'c' in my new scenario? I'm sorry for the length of the question
but I think it's important to understand the setup.
If you have a table of x,y, and desired z..
I can calculate the a and b constants using a least squares technique.
I am working now, but it is easy with Mathcad.
You might get by like this:
assume x is 0. Now find the soluition to z = b*y +c
next assume y is 0. Now find the solution to z = a*x+c
The least squares can solve for x,y, z at once.
Thanks Peter for your quick reply. It has jogged some brain cells. After my lunch and a couple of games of Freecell (to get the mind off the problem for a moment) I think I'm now coming up with a method that I can do on the PLC (AB MicroLogix 1200 by the way).
Thought this might be a fun problem to post here. I want to create a pump system that will give me 5 gallons. I am using a flow meter to do...
27
4,981
Dear all, I have a Lenze 33.8218E VFD which is controlling the motor of machine. It was stop suddenly, and could not run again. There was an error...
1,461
I use Vijeo citect with Modicon M340 with Ethernet ( Modbus/TCP ) Citect read all variable ( Bool - Int ) but didnot need to write any variable ...
2,563
I'm having a problem creating variable tag array in Citect SCADA V7.40. I looked every possible help, user guide... but no matter how i set...
4,758
We checked voltages, p.supply, cable, teminator resistor,etc. rslogix sees all vfds 16 devicenet vfds are all connected but only one can accepts...
6,565
