Dear Experts,
I am facing a peculiar problem:
In PLC blocks... in FC31 network-4, I want to change the IN1 parameter (which is 1.600000e+002) to 1.600000e+001.
After changing I am not able to save as well as download to CPU....I am getting the error
"Type Conflict with enty in the symbol table" and by going to help I am seeing this message:
Help on Message 34:146
Description of Error:
The parameter you supplied is defined in the symbol table assigned to your resource. The data type entered in the symbol does not match your formal parameter.
To Correct or Avoid Error:
Check your symbol table and change the data type for the symbol if necessary. You can also change the interface of the called block after you delete the call. This action affects all users of the called block and leads to an expanded display.
I think the solution may be simple but I do not know and require you people help.
