UART Question...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
I'm getting tired of the constant cable-swapping zzzzz so I'm adding a few additional serial ports to my desktop (Having only 2 just doesn't cut it anymore).
While shopping around, I see that I have a choice of specifying 16550, 16650, or 16850 UARTs. Of course, as the size of the buffer goes up, so does the cost. :rolleyes:
I only use these serial ports for communication to PLCs, HMIs, servo drives, etc. (you know, the stuff we program for a living), and rarely need to exceed 19.2 kbps.
So my question is: Does it really make a difference which UART I choose? IOW, are there any advantages (that I'll notice?) by having a larger buffer? :confused:
With the lack of Legacy ports on many new laptops, there's been a lot of confusion as to which serial adapters (USB and PCMCIA) are compatible with which PLC hardware. Though my question shouldn't be related to this, I just don't want to get stuck with a useless serial card. mddr
TIA for any input,
-Eric
If you're connecting to Allen-Bradley products, especially if you're going to attempt the 1747-PIC driver in RSLinx, go with good old 16550 UARTs.
The biggest serial port expander I've seen tested was just a 4-port PCI expander. RSLinx handled those 4 ports fine.
I use an older Quatech 2-port PCMCIA card and its performance has been perfect with all applications (RSLinx and many ASCII and Modbus utilities) I've tried on it.
The thing you gotta watch out for is being capable of using more serial ports. A serial port needs an IRQ, do you have 2 more that you can allocate.
I know, you can use a PCI card that "should" eliminate that problem. Verify that everything will comply.
You didnt mention 16750 or 16950...shouldnt matter overall, they "should" be backward compatible. If you dont see a need for faster than 57.6kps than stick with a standard card but from the prices I have seen checkout if the 16750 and up can go below 115k, if so there is no reason not to try one.
http://www.byterunner.com/why.html
http://www.quatech.com/
Both those sites have info on the chips and cards.
Thanks Guys.... Exactly the responses I was looking for.:D
Just so happens I was looking at Quatech stuff!
beerchug
-Eric
P.S. Ron, that byterunner link was very informative!
Hello, this is a brand new task for me. I recently bought a particulate sensor and it communicates with UART protocol or I2C protocol. It came...
2,888
Hi, i've got really annoying problem while downloading soft to OP7. I've got Protool v60 sp2, OP7. When I start downloading bootloader downloads...
5,775
I have a 120V relay, 120V DI card and a analog input. I was wanting to know if i could put a 24V DI and well as a 120V DI card on the same plc...
89
Hello again..trying something on an existing poorly written program and just wanted to double check something system is an A-B MicroLogix 1200 In...
197
Good morning! Let me start by saying, I am still learning about this type of HMI programming. I recently watched a video about recipes and how it...
195
