UDP message from a AB MicroLogix 1400 to PC ?
the addition of a digi one iap to your micrologix 1400 network will be able to convert ethernet/ip (tcp) to ethernet/ip (udp).
it can also convert modbus/tcp to modbus/udp.
(udp messaging is often preferred over cellular data links.)
hope this helps!
Is it possible to write and read UDP messages with the ControlLogix processors? I am guessing no. This was asked a long time ago but I wasn't...
4,454
Hello all, I am working on a project utilizing an s7-1200 cpu and Tia Portal v17. I currently have an external PCB with some sensors on it (and...
740
Hi PLCTalk Family, I am currently using S71200 for UDP communication in one of our projects. Recently due to the chip shortage looking out to...
1,298
Hi all, I was trying to communicate FX3GE PLC with KEPServer / Kepware via UDP protocol but did not succeed. Does anybody has any solution or...
1,072
Hello, I am using a 1756-EN2T and tryin to communicate with a device that accepts ASCII string over ehternet usin UDP. Do packets sent using CIP...
1,806
