UDT usage in SCL illegal data transfer Error
MOeZ
Nov 2009
singapore
101
Hello Expert,
i have illegal data transfer error while i compile below code and please point me where i did mistake :oops:. That is only self homework and thanks in advance.
TYPE VALVE
STRUCT
OP_LS : BOOL ;
CL_LS : BOOL ;
AUTO : BOOL ;
MANU : BOOL ;
OPENED : BOOL ;
CLOSED : BOOL ;
Q_SE : BOOL ;
Q_ERROR : BOOL ;
END_STRUCT;
FUNCTION_BLOCK BDV_TEMP // FB 1
VAR_IN_OUT
BDVTEMP : VALVE ;
END_VAR
BEGIN
IF BDVTEMP.OP_LS AND NOT BDVTEMP.CL_LS THEN
BDVTEMP.OPENED := TRUE ;
BDVTEMP.CLOSED := FALSE ;
BDVTEMP.Q_ERROR := FALSE ;
ELSE
END_IF;
END_FUNCTION_BLOCK
FUNCTION_BLOCK BDV_TEMP_CALL // FB 2
VAR_IN_OUT
BDV509 : VALVE ;
END_VAR
VAR
VALVE1 : BDV_TEMP ; // CALL FB1
END_VAR
BEGIN
VALVE1 (BDVTEMP := BDV509);
END_FUNCTION_BLOCK
As always, many thanks LD. even i read your link and screen shot, still i don't get it. :unsure: Can i have sample project or coding?
I'm focusing on Rockwell programming for a couple of projects, and I've been thinking about some of the details I've come across while working...
2,362
Can anyone tell me why my variables are red in the attached picture? I just started to use siemens and I am trying to understand how udt works...
3,137
Afternoon all, I'm working on setting up a large excel recipe table for porting updates through the Linx Gateway RTD/DDE function into my recipe...
123
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
211
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
155
