UL Approved Ferrules or Crimpers?
theColonel26
Feb 2014
West Michigan
785
So what does it take to be UL compliant with Ferrules?
Is there such a thing as UL Approved Crimpers? or do you have to use the manufacture recommended crimpers with your UL Listed ferrules?
I am unsure as to what I need to do to me UL Compliant here.
Attached is the UL conditions of acceptability for ferrules. I hope it helps.
BTW, you can get this off of the UL website by putting in the UL file number for the ferrules and then getting the additional info from the left pane.
Not really that document is very ambiguous :unsure:
Use of specific tools — A specific tool and die used to assemble a wire connector to a conductor is identified on the connector, or on or within
the unit container of the connector. The identification consists of a catalog or type designation, color-coding, die index number, or equivalent
means. Color-coding of the crimp barrel is common.
Clear as mud
Hi, Do you guys know of any marine (ABS or DNV) approved modbus TCP solution for Rockwell Controllogix? Our system: Redundant 1756-L72 - Act as...
2,066
Mundane, But with four out of five cards having broken "hanger clips" (if that is the correct term) I'm just wondering if I might gain from...
1,924
Any of you guys using an electronic wet floor sensor that is UL listed? Marc
4,014
Someone forwarded this to me today.... And since I don't remember seeing it linked before, here it goes. The Osha Cowboy I especially like...
2,313
when does one become an approved plc worker ?:cool:
4,535
