UL508A GFCI Test
RBergmann
Jun 2002
California
258
As many of us are involved in designing control panels as well as programming the PLCs that are installed in them, I have a customer who was cited by his inspector for the following:
He uses a GFCI outlet for most of his ICPs. The inspector told him that he must also have a testing schedule and signoff for the testing of the GFCI outlet. I've not heard of this. In my research in the latest UL508A Standard, I can find no reference to testing, or recording results of tests, of GFCI outlets. I realize there must be appropriate supplementary protection but a UL508A testing requirement for ICP installed GFCI outlets?
Anyone heard of this?
What a crock. I would be tempted to leave off the receptacle, or change to a non-GFCI.
I have seen little sheets that come with some GFCI receptacles for the owner to check off the dates when the GFCI was tested, but have not heard of forcing a secondary manufacturer to provide the test sheets.
My feeling is that the inspector is confusing other standards with UL508A. Some of these guys have more duties than just panel shops. He's (the inspector) the reason the GFCI is used in place of a standard receptacle. told my customer this was needed in UL508A panels. I ran a certified shop for 20 years and never heard of either the testing or GFCI requirement for a general use ICP. The one thing that was never mentioned is the labeling for a restricted max supplementary protection for the outlet.
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
397
Is there anyone that can give me the run-down on differences that are required for control panels sold in European markets, compared to those for...
748
Anybody have a recent experience becoming a UL508A panel shop? If so, how long did it take from initial contact to being able to apply stickers...
1,238
Hello, do 3 PH AC Servo Motors ( 1S Omron) follow the same rules as regular AC servo Motors? can I use Table 50.1 (UL508) to calculate FLC of...
2,042
  • Poll
Luckily, I do not have to worry about this test, but I am creating this poll for atc2222.
36
40,552
