Ultra 3000 DSD error #10 help
loundeb2
Jul 2010
ny
111
I've attached a copy of the Ultraware program I have for a flying shear cutoff.
The problem I'm having is when they increase the speed of the line, the shear comes out and the drive faults #10 (bus overvoltage). It mentions reducing the acceleration rate. Would disabling the slew limit help this? How do I increase the acceleration without faulting?
Thank You,
Lou
This is a classic "Regeneration" fault- when the drive is decelerated with a too steep of a rate, the system inertia will cause the drive to "inject regenerated voltage" within the drive's DC bus eventually exceeding the rated/allowed maximum level ; your system is either "undersized" for the application's demands or, if there is "room" you could try decreasing the deceleration rate; an externally installed resistive shunt could also alleviate the issue.
Please help to clear fault # 19 positioning error on Allen Bradley Ultra 3000 Digital Servo Drive using AB Utra Software Thank You
18,090
Hello All, Question about an AB Ultra 3000 servo drive (with DeviceNet), perhaps someone has seen this before... On power-up, the green LED for...
1,637
We are pulling our hair out trying to figure out this issue. We have an AB*MPL-A330P-HK22AA servo motor that started randomly throwing E22 and E24...
2,592
Hello All, I am having an issue with a Ultra 3000 jumping while stopped. It seem to be intermittent. I am using RS5K to control the servo. It...
2,591
Hello everybody, I need some help. I have flying shear application and trying to upgrade drive. Here is parts I planning to use: Ultra 3000 wit...
1,458
