Unable to get data to CP1E from Hyperterminal
Lazy_Fox
Mar 2019
OuterSpace
Hello,
I am trying to connect my CP1E-NA20DR-A with hyperterminal and get data from hyperterminal to the PLC. I used RXD instruction to store the data from hyperterminal to the D100 register.
I've set the following communication parameters on both the devices:
Baud Rate: 9600
Format: 7-2-E
I am using an standard 2-3-5 RS 232 cable for communication and use the on device RS-232C.
But, the data sent through hyperterminal is not received by the PLC i.e data not stored in regeister.
Hello,
Baud Rate: 9600
Format: 7-2-E
omron does not use the standard 2-3-5 pins for rs-232
2 - tx
3 - rx
9 - sg
I changed the wiring to 2-3-9 but, I haven't received the data yet.
Have you set the number of bytes to be received or an end code. Also check the other bits i.e. A392.04 Error (needs the port to be re-started) A392.07 etc.
Hello, I have been trying to figure out how to edit data type for an AOI in Studio 5000. I keep getting an error "unable to modify data type...
538
Can anyone help me getting this comms connection set up? I am using Port 2 on the Versamax ICU200UDR005-DK, set in SNP with port settings Baud...
1,560
Hello guys! Good day Everyone! We have a problem on the FTView Studio DataLog. I've created two different Bit of Data source (ODBC) which are the...
5,817
I'm trying to create a factorytalk 7.0 .mer file in factorytalk ME. As of a few weeks ago this worked fine on my computer and I'm not sure what...
2,646
Hello to all, I encounter this issue "Unable to save RSLinx Enterprise data server information. Would you like to continue creating the runtime...
5,334
