Undocumented program changes
ValeoBill
Aug 2019
Wasaga Beach, Ontario
87
Some help with an annoying problem, please....the majority of program changes (AB5000 platform) are being made by a contractor (a former employee here). His changes are not documented. I can tell from the "kb" stamp on the program file that changes have been made. Is there an easy way of determining where the changes are? The program structure has not changed in that the number and names of subroutines has not changed. If more clarification is needed in order to supply an answer, by all means, ask away. This issue - ongoing and unadressed by my "superiors" - is proving to be a royal PITA.
My thanks.
There is a logic compare tool, should highlight changes. You will need two copies of the program, typically whatever is on your computer, compared to the running logic uploaded from the controller.
are they in good standing with the company?
i would have purchasing write into their po that all program changes must be documented and that payment will not be completed until all parties involved with the changes and associated documentation.
just my 2 cents
james
Attached is an undocumented "feature" in GEIP PLC's that allows one to Download and run your logic but as of today there is no way to upload the...
1,976
After making my latest video and discussing some features about Beckhoff and a few features that are undocumented or buried very deep, it came to...
7,974
I've been helping out a contractor friend who has picked up several customers who use Direct Logic PLC's talking over spread spectrum radio via...
2,049
172
Hi, i am using DVP-14SS2 PLC, after program written to plc, when power is reset, plc doesn't run. always need to connect to pc for the run mode.
32
