Unidrive sp1406 problem
das100
Mar 2018
lagos
Hello guys,I bought 4 unidrive sp 1406 from a demolition,and I want to use them for some ongoing projects,but this drive are all locked by former user,we have tried to reset with cable ,with pad but no success.please guys can one direct me on any way to unlock through the backdoor as stated in their manual
Thanks in advance :geek::geek:
Maybe this is what you have already tried: My manual says that setting parameter xx.00 to 149, then press M, will open standard security. If User security has been established, enter a code between 1 and 256 (except 149) into xx.00.
I can't input any parameter it just ask for code,only 00.48 for inputting lock type.parameter 00.34 is code from 0-999,tried but can't get it to unlock.dont just know what else to do.control technics support not responding to my mail,please I need help guys thanks
Unidrive SP Forgotten Security Code
It is possible to discover the security code stored using the following procedure:
1) Power down the drive
2) Press the rev and down buttons and power up the drive
3) Read the value in parameter 11.30 – this is the security code which has been set
4) Press mode and access to the parameters is now given
5) A new security code can now be entered into Pr 11.30
hello everyone, trying to find a way to read/write memory of the PLC that is inside Unidrive M700 over Ethernet (modbus TCP) using device/server...
562
Greetings experts, We have a 'Control Techniques' Unidrive 3405 in an older machine. It appears that the drive parameters are recorded in a .CTD...
729
Hi We intend to replace our LENZE EVS9326 EP with a Control Technique Unidrive SP. The machine is a simple one; PLC send ABZ pulses to the drive...
2,048
Looking for a Modbus address manual for M700. Modbus address is same as the Parameter number for 16Int parameters. But it is different for 32Int...
2,000
Hello, new here, so let's start :) I am having some issues with kinco mt series hmi, mt4414te. Kinco and unidrive sp are connected via modbus...
3,955
