Unity FBD Diff Up and Reset Bit
rory
Nov 2005
NELSON
29
Obviously this is peice of cake in LD, how do you do it in a FBD.
Diff up, positive transition contact.
There is a SET FBD but no Reset FBD? I'm negating the output pin on a SET but that seems a bit too sneaky.
Rory
Are you talking about Siemens 300/400?
If so;
R - reset
S - set
P - positive edge detection
All available in the 'Bit Logic' folder of the list of functions. Or by dropping in an empty box (with the ??) and typing R,S or P
Pulse
It's R_TRIG for rising edge and F_TRIG for falling edge then u can define the pulse duration. All u have to do is in FBD press Ctrl+I to insert then it will give u a box. Then u can simply type the function u need inside the box. In your case type R_TRIG or RESET.
Hi there! A while back i came accross a website where people could post their custom FBD's for others to download. Unfortunately I can't seem to...
1,393
Hi, I have some experience with RSLogix 500 and ladder logic programming. I understand the concept of functional block programming, but I don't...
3,829
How to I trigger on a positive transition oneshot in function block? In ladder I just use the |P| coil, but can't find anything similar in...
4,438
input_1 output_1 ---||-----------() How do I turn on an output when an input is turned on in FBD? Not latched, just momentarily. If anyone...
5,319
Hello, Which function block in (FBD Language in Unity Pro XL 8.0) can I use to move a constant into a floating point register, if the permissive...
3,688
