Unity Pro and ATV61 - program example
pazuzu
Jul 2013
Poland
18
Hi
I have an a applcation with SE M340 and ATV61.
I want to control frequency and start and stop the ATV61.
I have a correctly configured connection (i've hope) and i want to send to my device information about desired frequency.
I use a IODDT structure (pic.1) for ATV61_standard and MOVE function to send information on the specified adres (pic.2).
data_editor.jpgPIC 1
test_fbd.jpgPIC 2
Please tell me if it's work and if there is any manual where are described thos parameter of IODDT structure.
Thanks!!!
Brendonh : thanks for replay.
\i figure it out. I use a PDO's and ewerything work fine.
Thanks for Your interesting.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
183
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
406
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
725
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,939
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
777
