Unity pro; determine address register of a variable
Machinery
May 2004
25
Hi, I'm working on a project and building a dfb. What I need is the address-register of a variable and using it for a start-adress. (see "READ_U_PCMCIA".RCPT). I know in IEC-developer you can use "GET_INT_ADDR" and Simatic_S7 "LAR1".
Tnx,
Not quite sure this is the answer u r looking for. Press CTRL + I then it will open the Function Input Assistant. Now you can just type the function you want or pick from the pull down menu.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,934
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
