Unity Pro - DFB parameters
euler13
Nov 2015
Cairo
Hi Friends,
I`m new to schneider PLCs and unity pro software,and with a very good background in siemens PLCs. I want to know when I`m creating a user defined function block DFB, when to use the Inputs\outputs parameters and Public parameters? especially if I have variables resuted from the logic and they are written and read inside the block and I want them to be connected to Vijeo Citect.
I use input/output for variables that need to persist between execution of the DFB, i.e. motor run hours. I put a motor run hours variable into the DFB, logic inside increases it while the motor is running, then the new motor run hours is output.
That's probably a terrible explanation but it's really the only time i use it for dfbs.
I have never had a need to use public variables so I'm not sure about those
Maybe this will help.
ETA: cant see the pic. In the Unity Help index, search for "public variable" and this will pop up. It explains the difference between public and private variables.
I've used Schneider Electric and Unity Pro for a long time and have always assigned a variable external to the DFB and then assigned that external...
3,529
I'm trying to find "IEC_BMDI_M" to use in my converted Unity Pro program to replace the old Concept "IEC_BMDI" but I can't find it in the...
2,403
I have a problem for importing DFB Blocks in a project of Unity Pro V3.0. I have a compressed file containing the Database of DFB Blocks with a...
5,939
Hello again, I was just wondering, I have 2 separate DFBs 1 to find the level of product and another to scale it according to Specific Gravity of...
2,102
Hi everyone, i wanted to ask if its possible to read public variables on a DFB's instance on Unity Pro S, from vijeo citect 7.2 using OPC OFS. I...
4,295
