Unity Pro Schneider
carretto
Feb 2013
Chapecó
There is an easy way to organize the tags in a DFB in Schneider's Unity Pro software. I can only change the order by deleting and creating
they have numbers in the "no." column. you can change those numbers and it will change the order in which they appear on the DFB.
Hi rankhornjp, thanks for your answer!
But the column no. is empty, and I can not insert anything into it
Is there any configuration in the software to allow this?
Thank you!
I see that you are using public tags. The "NO" column is for input or output tags. It puts them in order on the DFB when you use it in logic.
I don't know that you can reorder public or private tags, easily.
Thank you for your attention and collaboration.
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
I want transfer my I/O data from schneider (Unity Pro) as a write data and RS Logix 5000 as a read data. I use Ethernet as an communication...
696
Is there a tool to convert a ControlExpert project (.sta, .ztx or .zef in v14.1 or v15) to be opened using Unity Pro (v11 or V10) ? Thanks,
2,248
Hi all, I'm sure this is a stupidly simple question, but I'm really struggling to find any EFB or similar to do this. I want to map a block of...
3,408
Hi All, Can anyone explain to me: 1) What are 'PLC initialisation values", 2) What are 'Local initialisation values', and 3) Why I am getting a...
7,695
