Unity Pro XL and Citect SCADA v7.20
Strokur
Jan 2014
Ohio
62
Hi all,
I was asked by a coworker if there's a way when a slider on the Citect screen will force/change the position of another slider on the same screen. I'm mainly the person who handles all the PLC related questions or troubleshooting.
My worries would be if something on Citect side is forcing something I'll have the PLC reading multiple values for one slider. The same more or less if I try to do this on the PLC side, only it may not see one of the sliders active.
I expect if there is a way it's going to be handled by the Citect guy. (I wouldn't mind learning more with Citect as I don't know much) I appreciate any and all input.
Phil
Well Strokur If I understand correctly,if one slider also changes the value of another slider and both are link to the same value then both sliders will have the same value the whole time. Cant c how you would get different values from the sliders
Hi all, I have a system running a Modicon M340 with Unity Pro and a Magelis Compact iPC with Citect SCADA v7.0 connected via a managed ethernet...
2,994
I have an existing system in which I am sarisfactorily reading some drives run feedback using M340 PLC and citect scada. Now I want to give run...
1,496
Hello, I am unable to import the tags from Unity Pro XL into the Citect SCADA. Can anyone help? The unity pro xl 11.0 and citect scada 2015...
1,851
Hi guys! I am working with Unity pro and Vijeo citect. I am getting TT input on PLC analog input model addressd as %IW0.1.0 where in the citect...
2,704
Hi everyone, i wanted to ask if its possible to read public variables on a DFB's instance on Unity Pro S, from vijeo citect 7.2 using OPC OFS. I...
4,297
