Unity Pro XL forced bits not showing?
Jun 2017
TX
So I have a dryer project that connects to the PLC and says "equal". When I connect it shows there are forced bits, but when I double-click on the red "F" it brings up an empty table.
Any suggestions? I'd prefer to not leave forces in the PLC, so I'd like to fix the problem.
myself and other coworkers have experienced this problem too on M340 PLC.
versions Unity Pro XL V8.1 – 141023H and M340 PLC BMXP342020 version 2.6 – 4
Schneider asked if it happened in version 11 and I never bothered to upgrade to find out.
Don't think it will make any difference but maybe worth trying through the CPU config window under the information tab depending on your cpu type.
eAjJ65
also you have a fragmented memory error, might be worth doing a memory pack and trying again.
hyeqKQ
There are a lot of hotfixes for v8.1 that should be installed. They are all on the schneider website to download
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
180
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
405
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
724
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,937
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
