Unity Pro XL - how to pass parameters to Subroutine?
FNC
May 2010
NJ
84
I have a small piece of code (4 lines) that I need to repeat many times over.
How do I create a subroutine with parameters?
I have many subroutines but none that I can pass parameters to.
Thanks!
Create a DFB (defined function block). The inputs to the DFB are your input parameters and the outputs will be the result
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
188
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
409
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
732
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,945
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
780
