Unity Pro XL Import from Excel
RheinhardtP
Oct 2004
Perth
562
Has anyone imported variables from a Text file in Schneider Unity Pro XL, i have tried all with no soccess.
WHEN I IMPORT EVEN 1 VARIABLE I GET THE FOLLOWING MESSAGE:
"10_F6_BP00_PL01_JS01":
[char. pos. : 4]E1007 invalid integer literal
[char. pos. : 1]E1007 invalid identifier : 10_F6_BP00_PL01_JS01
import failed 1 error
10_F6_BP00_PL01_JS01 is my variable name
The format in excel is
Column A
Column B
-blank-
Column C
DDT_DigIn
Column D
Short Description
I have tried to export txt file then open as Tab delimeted and then edit data or variable and save as Tab delimeted TXT file but this is the message i get please help
Thank you
You cant have a variable that starts with a number
Well you can but you must set the project options to allow it
(I think it is under tools options)
Well done
(y)(n)o_O
Under tools the Tools-Project Setting-Language Extension-Allow Leading Digits Tickbox.
Many thanks
R
Hello, I am unable to import the tags from Unity Pro XL into the Citect SCADA. Can anyone help? The unity pro xl 11.0 and citect scada 2015...
1,851
I have a problem for importing DFB Blocks in a project of Unity Pro V3.0. I have a compressed file containing the Database of DFB Blocks with a...
5,939
I need to import tag file from Text file or excel file into Unity Pro:huh:
3,658
Has anyone here tried importing variable names from txt file into Unity pro XL. Whenever I try to export even one variable, i always get the...
5,633
Hello, So here is my problem, I have an existing program with the tags but now we have to change their names. So I exported the current database...
7,883
