Unity Pro XL MBP_MSTR Write Register
Ece
Jun 2016
NY
Hello,
I am trying to modify the MBP_MSTR FB in order to write data to another thirty part device.
Could you give me an example (which working) in order to write holding registers?
Thanks in advance
Hello,
Thanks in advance
Which PLC ? This is a Modbus Plus block is it not so would imply Quantum ?
Its a system block and can't be modified as such, only assigned and configured to read/write data ?
I would like to write 10 float to a flow computer. For this reason I am using the MSTR FB. Unfortunately I can not write to flow computer. In order to check if I have make mistake inthe configuration of MSTR I have already tested with a modus simulator and is works.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,934
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
