Unity Pro XL - PLC Simulator
Papplebeast
Oct 2014
Missouri
I've been trying to use the PLC Simulator with Unity Pro XL and the PLC connection keeps dropping after 5-15 minutes. If I try to reconnect, it fails. I have to use Task Manager to kill the process, restart sim.exe, and then I can reconnect. The connection drops again after 5-15 minutes. Rinse, repeat.
Has anyone else experienced this? Does anyone know why this might be happening and how I could fix it?
Thanks.
System Details
Operating System: Windows 7 Professional, 32-bit, Service Pack 1
Sim.exe File Version: 12.6.5.12
Unity Pro XL version: 7.0-120823C
Installed hotfixes: UnityPro_V70_HF20050524.shf, UnityPro_V70_HF20050594.shf, UnityPro_V70_HF20050890.shf, UnityPro_V70_HF20050593.shf
PLC program devices
PLC: 140 CPU 652 60
Power Supply: 140 CPS 114 20
I don't have an answer, but I have experienced the same problem. I just gave up trying to use it. I now have another processor on a test rack I use for testing.
I haven't had this issue since i upgraded to version 12. I skipped from 7 to 12, not sure if other versions corrected the issue
they put out new versions so frequently now. I skipped 7 and have stuck on 8.1. I don't ever recall seeing version 9, 10, or 11.
As I am between major projects now maybe the next ones we will upgrade to the latest version (13), but 12 seems like it might be destined to stick around longer.
All of the updates have been for the M580 and we've only deployed Quantum (pre-2012) and M340 since then.
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
As part of a comprehensive site survey, I have to mobilise to a remote site (offshore). I have also been asked to take a backup of their PLCs, so...
2,251
Hi All, Just wondering if anyone out there has a good comprehensive dual drive monitoring FB for Unity Pro, we had an issue on a site where a...
1,105
So I create a virtual M580 PLC in unity pro software and I have connected the virtual PLC with OPC client which is installed on another computer...
1,073
Hi All, Can anyone explain to me: 1) What are 'PLC initialisation values", 2) What are 'Local initialisation values', and 3) Why I am getting a...
7,692
