UnityPro Table/Recipe Programming
cheahcc
Nov 2014
ipoh
Hi All,
I'm new in UnityPro.
Can you all guys help me on the UnityPro Programming?
I need to create a Sequential Table (Recipe type format), this table has step no (sequnce no) will complete 1 by 1 step unitil the end.
Every step has its own data to do the operation sequnce like open valve, on motor, etc... After this step finished, it will jump to 2nd step to do the sequence, and 3rd step and so on....
This Table (recipe) can be stored in PLC. PLC can save more than 1 Table (recipe). These all Table can be store, edit and delete.
Can any 1 show me or provide me a sample programming?
Thanks.
Hi All,
I need to create a Sequential Table (Recipe type format), this table has step no (sequence no) will complete 1 by 1 step unitil the end.
Every step has its own data to do the operation sequence like open valve, on motor, etc... After this step finished, it will jump to 2nd step to do the sequence, and 3rd step and so on....
Thanks.
You need to read up about Derived Data Types (DDT) or ARRAYS for holding your recipes, and the ROR_*** or SHL instructions to control them, hold all your recipes in the DDT or array and control which one you want to read using a marker controlled by moving the marker in SHL etc.
You also don't mention which CPU you are using ?
No one here is going to give you finished products for free, which they have either had clients pay for or have invested their own time in.
Make a start, show some effort, attach what you've done and someone will take a look and provide assistance.
is it possible to external read the Forced_value list from a PLC using UnityPRO? I need to get this data. It could be via modbus, ops... or even...
2,444
Hi, I'm wanting to write a rung that clears a whole output card (64 bits 4 words). I can do it in structured text for each individual bit but...
1,310
Can someone please help me to overcome the version issue of unitypro software. I was trying to transfer the program in to PLC and it throws this...
3,669
Hi Everyone, Is there an RTO (Retentive Timer) function in UnityPro, or do I need to create the block on my own? Any tips would be appreciated...
1,648
Hi Guys, Have a simple question. New with UnityPRo V6.0 and Vijeo Designer. Need to slow the update time to analog channels on the HMI so the...
1,605
