universal analog input module??
mordred
Mar 2004
Red Deer
1,892
has anyone tried the universal analog input module 1746sc-ni8u? If so have they encountered any problems or can think of any safety reasons that the dedicated I/O modules would be better suited for?
I've never used that card, but have given it alot of thought. Looks like it would be a great card for a small machine, with mixed analogs.
I have used other specialty cards from Spectrum, and never had a problem. I use there 120V isolated input card for Motor starter control all the time. I've been considering trying the new 4 or 8 channel pulse card they have.
Ken
I never knew such a thing existed. 4 temperature loops... 4 current transducers... 1 slot... 10 slot rack instead of 13... Hmmmm...
Most Omron analogue input cards are multi input. You can select 0-10V, 1-5V, 0-20ma, 4-20ma or -10V/+10V in the set up window for the card. You can also select which outputs you wish to use and turn them on or off. Also select loss of signal detection etc etc.
If this card will give you all these features, highly recommended. Saves heaps obviously.
This is a truly unique card, it accepts:
voltage, current, thermocouples, or RTD inputs on any channel, all you
have to do is configure the card for the type of input you have.
Ken
yeah it will save a bundle on a project I'm working on I just hope
It'll be reliable enough to handle the environment I deal with. that being capable of near submersible. (high pressure washdowns)
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
64
I am a college student in my 2nd year of Automated systems and for my final project me and my classmate are looking to hook up a Universal Robots...
5,423
Anyone have any experience with them? Or cobots in general? I was recently exposed to universal robots and was quite impressed with their software...
3,795
Hi All, Has anyone written commands to a Universal robot dashboard through TCP/IP socket from an Allen Bradley Compact logix PLC? I'm using the...
2,121
any hint how i can make a pext or pulse timer using on delay timer in ladder logic. on delay timer is said to be a universal timer, all other...
2,381
