universal pack(italy)
emeka
Dec 2012
lagos state
34
hi guys,am having a problem on a universal pack,it is used to produce tomato in a factory..it was working,then suddenly it brought up an error(compressed air lack)...guys pls i need a solution asap..d factory manager is on my neck
So you have a machine called a "Universal Pack", built in Italy, that packages tomatoes. The machine has some kind of indicator that there is low air pressure.
What air pressure does it require ? What air pressure do you have ?
If the air pressure is sufficient, you should examine the air pressure sensor to see if it might be damaged or mis-wired. Describe it in as much detail as you can.
yes i have,d air pressure is sufficient and d sensor is not damaged...it has happend before and wat i did was to reset a plc in d pannel...cos d error displayin on the HMI says ''compressed air lack,find link and reset...so i dont knw wat else to do
Please use complete English words whenever possible.
Can you describe the PLC, or the circuit that connects the air sensor to the PLC ?
Did you perform the same reset procedure today as you did previously ?
Do you have a set of wiring diagrams for this machine that would allow you to trace the signal from the air pressure sensor ?
How did you determine that the air pressure sensor is working correctly ?
I would love to be able to help, but the amount of information you are giving is far too little.
WHAT is the air pressure please
also
is there a safety system that needs to be reset
Ian makes a good point: some systems consider an air pressure failure a safety risk, so the safety system may be tripped as well as the ordinary monitoring system.
Look for an "E-Stop Reset" or similar button.
i have reset all the plcs on the system but it is still not workin..when i looked at the wiring diagram..i saw a place labbled ''pressur switch compressed air lack''...there is also an air flow meter on the machine..d air flow meter is nt reading bt ther is flow of air from the inlet to the outlet..the model nmber of the universal pack machine is 'GAMMA-M5D' wit serial number 13p06 NG
What PLC is it?
the wiring diagram has an input number or wire number next to the description.
is that input on?
is the PLC in the RUN mode?
Can anyone recommend a universal USB to IrDA cable for interfacing with power meters? I see a lot of generic units but hoping someone has...
66
I am a college student in my 2nd year of Automated systems and for my final project me and my classmate are looking to hook up a Universal Robots...
5,428
Anyone have any experience with them? Or cobots in general? I was recently exposed to universal robots and was quite impressed with their software...
3,800
Hi All, Has anyone written commands to a Universal robot dashboard through TCP/IP socket from an Allen Bradley Compact logix PLC? I'm using the...
2,123
any hint how i can make a pext or pulse timer using on delay timer in ladder logic. on delay timer is said to be a universal timer, all other...
2,385
