Unlimited Pulse Output
Blevine
Mar 2018
Leicester
Aside from using the system bits like %S5, %S6 etc in SoMachine basic, are there any other ways to generate an unlimited amount of pulse that will trigger my Read_Var FB continuously?
Could someone show me the ladder diagram?
Thanks,
Blevine
Something like this: (Behold my wonderful ASCII ladder!)
myTON.Q
-|/|-----------------------[myTON]
myTON.Q
-| |---------(fbRead_VAR.TRIGGER)
I sent you an image over PM after following your diagram, but it seems like I can't make it trigger my ReadVar.
Any other suggestions?
Thanks,
Blevine
Thanks,
Blevine
I don't use SoMachine but do use Unity Pro, for Read_Var and i presume the instruction is similar so if it is you are going to want to check the Read_Var has actually successfully and the data is read and is complete using the status bits before you try and read it again or a whole heap of trouble will be met !
Thanks for your response. My READ_VAR is working perfectly fine whilst using system bit %S5 and %S6. However, I'd need a lot of these READ_VAR and I can't seem to reuse these system bits. I'm looking for alternatives to generate a rising edge or pulse to trigger my READ_VAR.
Blevine
Blevine
I'm sure it is, until one of the slaves doesn't respond, turn one of your slaves off and see what happens.
Good Morning , We plan on networking our entire plant. We have well over 255 machines. We have a block of IP Addresses we were thinking...
2,812
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
159
Hi All, I'd like to know can we use DTR instruction to get a week pulse ? Could anyone please help me to understand that one ? I've managed to...
184
Hello, I am struggling to figure out some logic. I have an analog pressure sensor coming into the PLC and would like to have multiple timing...
156
I have PLC Omron CJ2M with OD211 module. I want to use the pulse output and PWM output and this module. But i confuse how to activated this, i...
114
