Upgrade RSLinx 2.43 to 2.54 Issue
Darcy R
Nov 2008
Calgary
Hey all, I am attempting to upgrade a RSLinx install and right at the beginning it comes up with a "INTERAL ERROR 2711.WFCU" message comes up and the install stops.
I looked for the wfcu service to stop it but it doesn't look like it's even there...is that the problem? Do I need to install that application to get the install to work?
Thanks in advance!
WFCU = Windows Firewall Configuration Utility
Because RSLinx originates TCP connections on ports that a garden-variety firewall won't usually leave open (2222 and 44818), RSI included a utility that configures the Windows Firewall to work with RSLinx.
I've always had this run perfectly in the background and have never needed to touch it.
The first two things I'd do is verify that you have honest-to-goodness Administrator priveleges on the PC, and check the state of your Windows firewall. Determine also precisely what variation of the operating system and service pack you are running.
Thanks for the reply, I definitely have full admin privileges on the computer and it's running XP Pro SP2. The RSLinx install was the last part of a Controllogix upgrade and it failed at that point and all subsequent installs have failed with the same message.
Currently Windows Firewall is turned off...should it be on? I am kind of reaching but I haven't seen this problem before.
Thanks.
I've had this fail when the ICS service is disabled, Make sure both the firewall and ICS services are active for the install.
I figured out how to uninstall the old version and it starts installing 2.54 but times out while decompressing everything....I am doing this all through a remote connection too so it's a royal pain having to get someone to restart the machine.
I have never had this many issues installing RSLinx before, I must be missing something?
I have just downloaded and installed CCW software which upgraded my RSLinx to version 4.11. This has caused me a problem and I was wondering if...
2,567
I am running version 2.57, and just downloaded 2.59. When I upgrade, I normally get to the part where we update EDS files, then I go in and add a...
3,647
I want to perform a web update of my RSLinx software (I currently have RSLinx Classic Gateway version 2.50). On the Rockwell support site I have...
5,385
Hi, I have had problem with upgrading some projects from v16 to v18. I tried it on 3 diffrent computers. I want to post this so that anyone that...
173
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
172
