Upgrading PV PLus to 5.1
Patient
Jun 2012
Auckland
50
I've been struggling at bit trying to upgrade these screens from 5.0 and 4.x to 5.1. I've tried using the Ethernet connection (using panelview file transfer utility) option from the FUW and it says it can't find it. I can ping it and download screens to it but using FUW Ethernet won't work.
If that solution goes no where my other question would be. Can I use my usb thumb drive as a CF card and use that to upgrade firmware?
After getting a bit further I have tried to use a compactflash card to upgrade to 5.1 (from 5.0). Has anyone received a windows error 0x000000c1 failed to run autorun.exe??
I tried plugging a keyboard in and running the exe from the storage card directory using ctrl-shift-alt-windows to no avail. I was tempted to run exes in the upgrade folder but thought that was a bit too risky. Any advice??
I found the solution and realized that I was trying to over complicate the easiest of tasks. To anyone having a similar error Autorun failing to start or FUPs not showing up when you connect to a screen. It's because you have downloaded the wrong FUPs for your hardware.
My panelview runs firmware 9 just fine. I would like to understand the justification to upgrade the firmware to the latest. I've been asked to do...
1,636
We had to replace a bad Panelview plus 6. It was running factorytalk v5 and kepware v4. This unit is talking to two AB PLC 5s over DH+ and 3 TI...
1,837
Hello all, I am new to this site and fairly new to the automated world. What I am trying to do is upgrade a PV550 CAT#2711-T5A16L1 SER B FRN...
3,163
We had a panelview plus 700 talking to 2 PLC5s through DH+ and 3 TI 505 plcs through kepserver. This rig has been working great for a few years...
4,386
I just upgraded my Panelview Plus 1000 firmware and windows CE operating system from version 3.0 to Version 3.1. Everything went perfect except...
2,105
