Upload and Download to Panelview
Tim Ganz
Dec 2010
Dallas, Texas
691
I have a panelview standard connected with serial cable to a slc 5/04. Over a remote link can you upload and download a application using panelbuilder 32.
I know how to do the remote I/O pass through but this is connected with serial cable.
Network is DH+.
Is there a way to upload and downlaod the application without going to the site with this setup?
I have never done it but the manual seems to indicate it can be done, see pages 14-9 and 14-10. You will need to set-up the proper status bits and have the right firmware, all in the manual.
You have a recent post to an unrelated thread that might reveal what's going on.
And remember Mickey's PanelView Rule #1: Post the complete part number !
Your PanelView is probably using DH485 protocol over RS-232.
This means you need to run DH485 to connect directly to it, either using a 1747-UIC or going old-school and finding a way to run the 1747-PIC/AIC+ driver off a built-in serial port.
For Pass-Through to work between DH+ and DH485 on an SLC-5/04 is tricky... I'm not sure exactly which settings to use.
I wouldn't do either of these things: I would use a CompactFlash card in a Type II carrier and just transfer files to and from the PanelView terminal that way.
Hello, I have a machine with a 1756-L72 Controllogix PLC and 1756-EN2T network card, and PanelView Plus 7 HMI. I am using RSLogix V20.05.00...
906
I'm looking for an HMI that I could remotely (off location) upload a configuration, edit it, and then download back to the HMI. Is this possible...
2,199
Hi I have a panelview 550 I want to make some changes to, and I need to find out how to com with it. I have a allein bradley usb to serieal port...
2,970
I going to be working with an Allen Bradley Panelview 550 and need to make sure I have all the right cables and connections to Upload the program...
6,488
Goodday, I need explaination on how you succeeded in uploading/downloading the old program from panelview 1200, through DOS version of PDS.
5,201
