Uploading From A Yaskawa MP2300Siec
JKS
Dec 2014
Portsmouth, NH
56
Hi, folks;
I've got a small 2-axis pick & place robot that we're looking to make some changes to. It is controlled by a Yaskawa MP2300Siec with an LIO-04; the axis modules are SGDV-2R8A11B's.
The problem is that if we have the OEM's original programs, no one can find them. I've tried multiple times to get in touch with the OEM to get copies, and no one there wants to call me back.
I'm very un-familiar with Yaskawa's stuff, but figured I'd try to upload the programming and go from there. I'm using MotionWorks IEC 2 Express.
I have gotten basically less than no-where with it. All the manuals have proven to be less than helpful, so here I am: what am I missing and what should I be doing here? I can't seem to even get MW to see the MP2300, never mind figure out how upload the programming.
Any guidance at all would be greatly appreciated, even if it's just to tell me how dumb I was to over-look something obvious. Just... please point out the obvious, as at this point, I'm just lost.
Thanks, guys.
- Jeff
Hi, folks;
Thanks, guys.
- Jeff
If they did not include the source code in the factory download then you are pretty much SOL.
Much like most other PLCOpen systems source code downloads are optional.
You need to know the IP address of the controller. You can always force it to the default(192.168.1.1) with the DIP switch. Yes, it must have the source code on it for you to be able read it.
I've been struggling with adding a Yaskawa drive to an existing DeviceNet network. I installed a new Yaskawa drive and programmed the drive...
21
9,266
How can I access the web page that allows me to see and upload the pcl or translation file into my Pl1000E? My Pl1000E doesn’t have an ethernet...
136
Hi guys, I have had some issues with uploading a program from a Micro 850 PLC. This is the first time connecting so I don’t have a file on my...
302
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
175
Hi all, Im stuck trying to support a client with Motorola ACE.. I was able to upload all of the other sites to STS but one. Im working remotely...
118
