USB cable power switch
sparkyinak
May 2016
Ketchikan, AK
79
I'm looking for if it even exist is a switch to open and close a micro USB cable for a Bluetooth antenna that can turned off via remote contact. Would it help that the cable will be feed a PLC?.... lol!
Not sure of your exact arrangement but can you not just use a normal USB cable and split it through a relay ?
That's fine, but I have had no luck locating a relay, switch, what ever that will switch a micro USB connection. An A/B switch would work. It just need to be able to be switched with either 24VDC or 120VAC. I should be able to do the rest
Just chop the cable USB cable in half, run the +5vdc through a 24vdc control relay and take the data and 0v cables to terminals to join them again to the device with the other half of the cable.
Dear all, I have fx3u series plc with built in rs422 port and usb-sc09-fx cable. I have a a hyperterminal like application to send and receive...
243
Hello, I have a 1784-U2DN, and I have a flashing red light on the module status LED. Manual says I have a recoverable fault….but it doesnt say...
921
Good Morning , I just purchased a Windows 10 Hp Laptop. Of course no serial ports , but 3 USB ports . Need a USB to Serial cable to go to...
20
6,262
Hi everyone, I need to upload 2 Omron PLC programs from those PLC's: CQM1 CPU21 and CJ1M CPU22. On my laptop I have just USB ports. I have...
2,982
Hi, I recently purchased a Cpm1a plc to learn programming. I have syswin running on my windows 10 tablet and the plc came with a usb-cif02...
1,625
