USB PPI multi master cable problem
harrydeharry
May 2008
Delhi
237
Dear All,
some how we lost the USB side of the cable of our PPI adapter and now we don't know the USB pin configuration inside the PCB part a 4 pin white connector is there, can some one help us to connect a new USB cable to the same.
where to put on baord.
1 USB -- DataP
2 USB -- DataM
3 USB 5V
4 USB logic ground
Harry,
The problem is I dont know the manufacture of the cable or the part number... do you have a picture of your cable ?
We make and sell a PPI Multi-Master cable but unless you bought it from us it will not be the same, I have some original Siemens cables but need to know what one you have
MOST (not all) will have some writing on the board, this is so the tech or machine can solder it together
Still not sure how you 'lost' the wires?
Can't really see from the picture but... is that a USB "B" plug? if yes then you just need a USB A to B cable
Please help me. The DB9 on my USB/PPI converter was dammaged. I need to know the wire color to pin, with this i can install a new DB9. Thanks
1,592
Hi Dears, Anybody have driver of Usb-PPi multi master that send for me its file? that is for communication between of PLC and PC. I would be...
4,082
Hi Friends I’ am new here, so bare whit me. I have a problem regarding communication from Siemens S7-222 thru the PPI/USB cable. what I want...
3,649
Hi all, Before the computer decided to update windows 10 last night my cable was working fine.....now its not. Does anyone have the drivers...
2,488
Hello Guys, I'm trying to program S7 200 CPU 212 using USB/PPI mm ( 6ES7 901-3DB30 - 0XA0 ). Uploading the program from PLC is good but when I am...
2,015
