USB-Serial-Omron PLC
dread79
Guest
D
I have recently recieved a new laptop from work which doesn't have a serial output. This was remedied by using a USb-serial driver. For some reason I am unable to connect let along configure the serial communication. Does anyone have any suggestions (other than throwing the piece of **** out) ?
Dread, there have been numerous posts concerning this recently. Depending on the PLC involved, the USB/serial may or may not work. In my case for Allen Bradley I could do DF1 but not use a 1747-PIC. I didnt have problems with GE Fanuc (that surprised a GE Fanuc tech), or automationdirect. For Allen Bradley and Siemens I had to obtain the PCMCIA card, still have issues with Siemens in XP tho.
All in all I keep my personal laptop (IBM 300mhz with Win98) close by with all software etc loaded on it.
May want to check with Omron to see if they have an update to your Omron software to work with your OS, I assume the new laptop has Win2K or XP on it.
Another option (research this thoroughly) if you have Win2k/XP and the software wont work with either is to dual boot. The easiest way to do this is get Partition Magic to create another partition then install Win9x. I state research this thorougly because some of the newer laptops (especially XP systems) may not have the system/device drivers available for Win9x.
USB-serial for omron PLC
Hey,
have you already solve your problem.if not try to use a usb to serial cable with ATEN brand.it comes with a installer CD.i am using it for almost 3yrs and i got no problem with it.although it won't work with some PLC's like GE fanuc LM90 software base.
You can use Omron CS1W-CIF31 (USB to RS232 converter) which works with Omron PLCs and HMIs.
SVN
It could also be the laptop. I used an Omron converter (bought from Omron) that had been tested will all Omron hardware. The comms kept dropping out.
It was the HP laptop - changed the laptop and no more problems.
has any one went online with a omron c200hs plc using a usb to serial adaptor (belkin f5u409). i can go onlin with Allen Bradly plc, HMI's...
2,969
Hi all, I have a problem connecting Omron CQM1H to my laptop using USB to Serial. (my laptop come without serial port). Anyone can help me...
8,097
I have 5 packaging/label lines that use the Omron CPM2A processor that is interfacing with the following. Noax touchscreen, GSE 650 scale head...
14,042
Looking for recommendations for USB-C to serial adapters. Mainly used to connect to SLC and PLC5 processors.
178
Until recently, I haven't had to connect to a piece of hardware using a serial connection in quite sometime. Well, that all changed yesterday when...
33
6,357
