used plc
samoil
Feb 2006
indiana
22
I need simple Allen Bradley PLC for Rx Logix 500 software.Inputs and suply can be any, but outputs have to be for 125-250 DC loads.
Thanks,
Samoil
You did not say how many I/O and the outputs could still be any voltage, its common to use interposing relays on outputs.
Yes, I need to power some control coils on the old gear breaker Allis Chalmers which requires 125 and 250 DC.I am not alloud to redisign application....
Thank you for respond
You can get a 10 point Micrologix new for about $100. I would use interposing relays with the outputs. Interposing relays are relays that are controlled by the outputs but are capable of working with the voltage requirements of the application.
Has any used a ballistic pressure transducer with a PLC? I am not sure if it will capture the event that I need to use as a control. The device...
1,094
Good day all, Im just wondering if there are any existing hmi system tags that i can use as a plc input tag to indicate that there is a triggered...
1,081
I'm working on a temperature/humidity test chamber that was made in China sporting a TATO PLC that looks exactly like a Micrologix 1000. Also has...
3,307
Hi all! I have one question, it might be simple for one of you but I spent hours searching and reading through different platform until I found...
1,657
Does anyone have leads on places that will buy used functioning PLC components? Specifically Square D Sy/Max model 50 programmable controllers...
5,502
