User password change in FactoryTalk Directory
Switek
Nov 2008
Cork/Ireland
25
Hi all,
Application configuration:
HMI server FT SE Network, 9 FT SE Clients. Separate Domain controller with FT Directory on it.
FT SE v. 6.1, FTD 2.6
Security access to the system is maintained via FTD only (no windows authentication).
Security policy requires user to change the password every 60 days and here the fun begins:
1. User changes his password on the client_1.
2. Once logs onto the Client_2 (no matter how long after password change) user need to first type the old password and change it, as it looks that client is not logging it the network directory, but is uses the local copy of it.
I was told by Rockwell TechSupport to reboot the client_2, which I did and then I could use my new password, but this means that I would have to reboot all the clients each time when the password is changed (system has about 20 users). This could work as interim, but not as a solution. Until now they could not provide me some solution to it, so I was wondering if anyone of you had a similar problem.
I am pretty sure this will be some simple setting somewhere in the policies.
Clients are pointing to the Network FTD server. I also know that client cashes the copy of the FTD each time it reboots (that's why it works after reboot).
Any help will be much appreciated.
Thanks,
Switek
Hi.. I am making some improvements in a flexible project. And I have a page that is password protectet. I have createt a usergroup called...
3,421
Hello is their a way to create a password that contains the following variables: 1) number of the day in the month, example 07 the 7th day in...
744
Hi all, I have a job next week where I will be going online with a few ControlWave PLC's at a customer's site, and we do not know what the...
2,058
A pump station is running Wonderware System Platform 2012 R2. Security is through active directory. When a user logs in and changes their...
1,493
There is a project WinCC, run the project, request a login and password? How to determine the passwords for users in the User Administrator? Of...
2,254
