Using 1769-L33ER with Modbus Gateway
zacslade
Oct 2014
Phoenix, AZ
84
Hi All,
I am starting a project where I have a 1769-L33R which will communicate with modbus devices by means of a MDS TSXEGT100 Modbus Gateway. I'm still waiting on part numbers for the ethernet devices, but I want to get ready because this project doesn't have a lot of available time.
I haven't worked on this kind of protocol conversion before. In your experience, would it be normal for me to just add a Generic Ethernet Module for each modbus device in Logix Designer, and then input assembly instances, etc?
Thanks!
I am kind of confused - are your devices using serial connection to the gateway?
From what I found this is Modbus TCP to Modbus RTU converter.
Can you post link to the gateway manual?
In any case, it does not look like it supports Ethernet/IP protocol.
This means no I/O configuration and use Modbus application code using sockets.
If this is a case, you probably better to get 1769 Prosoft Modbus module
Thanks guys! This was just the kind of lead I needed.
I didn't notice that the device was for "Ethernet" but not "Ethernet IP", so I've got some more things to do before the project gets underway.
Thanks again!
Good Afternoon , I'm working on a project , and this project has a fairly large control panel with a 1769-L33ER processor. I would like to...
1,635
Hi Guys, First time using Rockwell CompactLogix PLC, I have no idea how to assign IP address to it. Now PLC is powered up, only 1 "OK" light is...
12,276
Using Rslogix 5000 Data Access manual as a reference I keep getting 'Service Not Supported' response when using symbol instance addressing to...
1,555
Good Morning , I'm thinking of using a 1734-IK with a CompactLogix 1769-L18ER. Looking at the manual it looks like that it needs to be used...
1,612
Hello all, I am doing a project where I need to use a 1769-L36ERM. I am developing offline as I am waiting for my hardware to arrive. I have a...
21
11,434
