Using a BuckBoost to go from 380V to 460V
gbradley
Apr 2002
Corona, Ca.
1,637
I’ve got these machines with two Servo Motors on them, 3KW, and 1KW, with Kinetix controllers.
They run here in the USA at 460V 60HZ
I shipped them to China where the voltage is 380V 50KHZ
Everything works great, the Kinetix controller don't seem to mind the lower voltage. Of course I had to change the Xfmr for the control voltage.
I have noticed that the reaction times of the motors are not as good there.
When I try and Accelerate, and Decelerate. I’m not getting as good of performance.
It’s hard to Quantify.
What I am considering is putting a Buck boost in front of the Line, so that the Machine gets 460V @ 50Hz.
I know I'll have to change back the control circuit transformers.
Anybody done anything like this before?
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
36
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
71
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
132
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
229
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
77
