DanYost
[font="]I have several customers who have asked about using our products, with program through capabilities, to program an AB PLC via DH485.
I am not overly familiar with the AB side of things, but it appears that the only driver in RSLinx capable of programming a SLC via DH485 is the PIC driver. The problem I am running into is that the driver will not load when I select a non-physical port on my PC. When I use HW-Group's VSP program the port I create, COM4, does not show up under Ports in device manager. It shows up under Eltima virtual serial ports.
My question is has anyone been able to get the PIC driver installed on a virtual port, or is there another driver in Linx I can use to program a SLC (or any other AB PLC) via DH485?
Thank you,[/font]
Thank you,[/font]
