Using crystal reports in wonderware
theluckygal
Jan 2015
morrisville
Hi, I downloaded the latest crystal reports & added a crystal reports object (Crystal ActiveX Report Viewer Control 14.0) on one of my wonderware windows (version 11.0) to view on my screen. I defined a memory message tag called 'report' & using this code:
report = "C:\Reports\report1.rpt";
#CRViewer1.ReportSource = report;
#CRViewer1.ViewReport;
But I get this error when I run the window:
Error processing CRViewer1.ReportSource' on setting string property (execute). Type mismatch on parameter 1. (DISP_E_TYPEMISMATCH)
I tried defining the 'report' tag like the following but I cannot validate the wonderware script:
Dim report As New CrystalReport1
The help online is mostly for visual basic & that code doesn't validate in wonderware.
Hi I'm very new to PLC programming and I'm trying to find out if this library (Tc2_NcFifoAxes) is necessary for our task In our case we need to...
38
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
79
Adding ethernet equipment to an existing panel that has none. We have some solid ethernet cables coming from other remote cabinets that I plan to...
134
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
250
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
79
