Using encoder with 1746-IB16 module
flyers
Sep 2006
Amk
295
Hi guys,
I'd like to to ask I can use the 1746-IB16 with a rotary encoder from Omron E6B2-CWZ62.
It's just for a training kit, I do not require very high accuracy position.
Thank you.
rPraveenkum said:
you should consider low ppr encoder
That's the only encoder I have from old projects, so if can use then I can save the cost of getting a new one.
See the signal delay spec for 1746-Ib16
Studio 5000 & PF 525, Ethernet Comms, Encoder FB, Using Motor RPM as speed reference I'm trying to figure out how to send a speed reference in...
964
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,335
A bit of background here: We use an incremental encoder with a counting module in our PLC configuration. Using dual phase / quadrature counting...
26
9,033
Hello everyone. I'm new to the forum. I have a problem with the encoder and PID. We need to turn an encoder controlled rollover. I am using...
1,406
Hello. I am working on a double sided labeling machine where is two parallel conveyors ,the bottles flows between them . The lower conveyor is...
1,339
