Speed synchronisation using encoder feedback
Hossamhegab
Sep 2019
Cairo
23
Hello.
I am working on a double sided labeling machine where is two parallel conveyors ,the bottles flows between them . The lower conveyor is the master conveyor and driven by AC motor and VFD and there's a rotary encoder mounted on directly on the shaft ,the upper conveyor is the slave and driven by servo motor ,
How can I synchronise the linear speed of the two conveyors.
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
160
Sigh, DeviceNet noob... I have a 1756-L55, with a DeviceNet module, and 10 PF700 all commanded with DeviceNet. One of the PF700's blew up...
133
Do i have to use interrupt subroutine, or immediate read high speed input, for Unitronics Samba plc or reading only the correponding register in...
124
Hi all, I'm having trouble solving a problem I've been working on for several months, and thought you might like a stab at it. The machine runs...
22
962
